Hi Ben,
You could try combining it with the last ID that was used. Data Verification will be after the capture stage.
In my environment the capture role is ID 20, so I would use
WHERE LastProcessedWithRoleId = '20' AND State = '5'.
Just in case, you can find your role ID's in the User Role table.
Ben Lyons
Product Consultant
UK
Ben Lyons
SS&C Blue Prism
UK based
