Hello there 🙂
I'm trying to use surface automation on a full sized window (I'm opening a PDF with IE). There are two issues with this:
1) Region Mode doesn't work on a maximised window. As of now I'm getting BP to resize the specified window as large as it can instead. But my question is, why can't it be used on a maximised window?
2) Some parts of the page is covered by the "Using the identification tool" (saying that it is in HTML mode, Win 32, AA, etc) pop-up at either corner of the screen. As I'm using "Read text with OCR" to read from the page, this presents to be a problem because the words underneath the pop-up cannot be read. Is there a way to remove the pop-up?
Also, to inform, I've already tried to copy and paste the text with Acrobat Reader, but the words are jumbled up. I assume that this is because the form has been filled using the "Fill and Sign" function in Acrobat Reader. Region mode also doesn't work on Acrobat reader, hence I'm using IE to perform the actions.
Hope this is clear enough to anyone who is reading. Thanks!
