13-05-20 04:35 PM
I have to call a process on a certain bot from a different process on a different bot. the aim is to have a central bot that is running a process and calling process on different bots.
Is there something available in blue prism to achieve this, also how will the central bot check if other bot is busy running something and in that case pass request to a different available bot.If all bots are busy, queue the request and as soon as next bot is free, it picks up the request.
Mayank Goyal
Mayank Goyal
23 REPLIES 23
29-06-20 02:27 PM
@Mayank Goyal I haven't tried the inteface using SSO myself, but after looking through the Help files it looks like you might have to use a combination of AutomateC and the HTTP interface. There is a flag for the HTTP interface called internalauth. You can pass this command in along with a single-use token, created using AutomateC, to authenticate yourself.
Cheers
Cheers
29-06-20 02:56 PM
Ah, I see Bruce Liu got you better directions on this thread.
22-10-20 12:07 PM
I have the same problem. did you get any solution for this ?
Kashish Jain
Application Engineer
Schneider Electric
Kashish Jain
Schneider Electric
23-10-20 06:44 AM
@KashishJain - If your issue is regarding how to use http in SSO, use command http://machinename:8181/user%20name%20username&password%20password&status.
If its a different issue, the please provide details on the same
Mayank Goyal
Mayank Goyal
- « Previous
- Next »
