Runtime machine in a Group
ManojKumar3
HI Team, AS of now we need to specify the runtime machine name where the process needs to be executed while scheduling but my query is can we  create a Group and place all the runtime machine in that grp and assign the process to that particular group and based on the available resource the respective machine in that group should act as runtime bot so is it possible in 6.4 version???
AmiBarrett
Level 12
Yes - this is called a Resource Pool. You can configure it from System -> Resources -> Pools. When creating your schedule, you can assign it to the pool instead of the specific resource. This will then kick it off on the next available resource in the pool, in order of top to bottom.
