SAP Element ID Wildcard/Dynamic
Kevin_RodneySan
Hi, Has anyone tried setting the Match Type of a SAP Element's ID to Wildcard or Dynamic and got it to work? I'm getting errors whenever I try to access one of the elements if it is opened in a different session/window of SAP because the SAP's element ID is specific for the session I spied it from. Thanks!
Level 15
I doubt very much that would work. Attributes such as SAP ID, HTML ID, HTML Path, etc tend to be exact look up.
l.kiciak
Hi Santoska, there is a possibility to specify the session or window. For that you need to choose a ""Dynamic"" reference to SAP Field. Regards, Lukasz
CecileDurand
When I select ""Dynamic"" it grays out the Value yet it still cannot highlight the element. Could a wildcard be used in the ses
  • ? What would be the best to use there? #?
