SAP SRM GUI SPY mode not working
ManasJena
Hi ,
We are trying to SPY SAP SRM GUI. We have enabled both server and client side scripts. Still the SPY mode doesn't work. Attcahed are few screenshots.
Any suggestion how to proceed with this ?
Manas Jena
Sr Analyst
ZimmerBiomet
America/New_York
_Amlansahoo
Level 11
Hi Manas,
Are you able to spy any element other than this window(Like User name, Password, or some fields after login) using SAP Mode?
If yes then there are some window in SAP like which are non editable then you can not able to spy it. Try using Accessibility mode if using that you can not able to achieve your requirement, then generate a script using using SAP GUI Recorder and use it code stage to achieve it.
It is very simple to use.
Let me know if you have any doubts.
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
Thanks ! Amlan
Yes I am able to spy other elements .Attached is a screenshot what I can spy on the same screen.What is Accessibility mode and how to leverage that in this scenario ?
Manas Jena
Sr Analyst
ZimmerBiomet
America/New_York
Hi Manas,
Are you spying using SAP Mode or any other mode.
AA mode is different spying mode which is present in BluePrism.
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
