SAP Scripting in Code Stage
Daniel_JebarajJ
Hi All, I know the SAP GUI scripting works well with Microsoft Excel. Is there a way to execute SAP scripts in code stage in Blue Prism? If Yes, What needs to be done in this case?   Regards, Daniel
6 REPLIES 6
Davidde_Miguel
I want to Know the same.   Please could somebody helps us?
chrrom
Hi, it is possible either by spying exact way as you would start SAP script manually.. OR faster way is to start SAP script via Utility - Environment --> ""Start process"" where you insert script path.
Davidde_Miguel
I know it, but i don´t want to put code in files to execute it, i want to develop the code in Blueprism
This can be achieved using Code Stage.
Step 1:  Have your script ready. In my case , I use the SAP recording feature (Customize Layout - > Script Recording and Play Back) to generate               script.
             From the generated script Recording take code starting from "session.findById("wnd[0]").maximize ......"
Step 2: Go to Initialize action in BO- under code options add the below name space
             "Microsoft.VisualBasic.Interaction"
Step 3: Open your code stage in any action and add these lines in it :
             Dim SapGuiAuto As Object
             Dim session As Object
             Dim Application As Object
             Dim Connection As Object
             SapGuiAuto  = GetObject("SAPGUI")
             Application = SapGuiAuto.GetScriptingEngine
             Connection = Application.Children(0)
             session    = Connection.Children(0)
Step 4: Now add your code from Step 1 in the after above line in code stage.
It will work fine.
Sharath Kumar Pennada
Consultant
Deloitte Consulting India Private Limited
Hi Sharath Kumar Pennada,
When I use
If Not IsObject(session) Then
End If
then Blue Prism complained that IsObject is not declared. Do you know which namespace I have to import for that to work?
Thank you and best regards
Hoài Anh Ngô Vi
Technical Consultant
NTT DATA
Europe/Berlin
Hi Hoài Anh Ngô Vi ,
Please follow the steps mentioned above.
Step 2: have the namespace.
Step 3: You have to use entire code mentioned there.
Sharath
Consultant
