SQL Query not working
23-11-20 09:31 AM
I'm facing an issue,
I'm trying to input some data into an SQL table from collection, but its not working. When I'm running it just in the object its fine but when a try to run it in my process its not working. I tried to run step by step and like that its working as well,but when i try to run the process alone its not working. It's executing but not inserting into DB.
Thank you for your response.
Peter Vígh
23-11-20 11:55 AM
Cheers
23-11-20 12:40 PM
Peter Vígh
23-11-20 01:09 PM
Could you please share screenshot of your DB process.
Nilesh Jadhav
Senior RPA Specialist
ADP
India
Consultant
ADP,India
23-11-20 01:13 PM
Peter Vígh
23-11-20 01:34 PM
Cas zaciatku = Start Time
Cas ukoncenia = End Time
Vytvorenie SQL prikazu = Creating SQL command
Peter Vígh
23-11-20 01:49 PM
Peter Vígh
23-11-20 03:00 PM
Do you call the Configure action of the VBO anywhere? If not, you may want to call that first and set the Raise Exception on Any Failure flag to True. That way, if the transaction is hitting some weird SQL exception you should see it.
23-11-20 05:03 PM
The problem was somewhere else,the file download was too slow and he started insert before that file.
But i have another question,in the top left bar we have the error icon it is showing me that i have 2 errors but when i open it ,it shows me 0 errors.
So now, i have errors? Or what is that?
Peter Vígh
23-11-20 06:01 PM
While you're in the dialog you can tell it to recheck by clicking the "Check Again" button on the left of the form.
