Hi Tejaskumar,
Unfortunately I don't have enough information to give you a specific answer, however there are a few things you can try.
- If the field is always in the same place of the document, you can use the misc parameter "StrictPosition=On". This is per layout and so the location can still vary between different suppliers/vendors/etc.
- Sample headers should generally be unique (where possible), if this isn't possible you might want to try without this particular one being added to the DFD.
- If the values can in any way be anticipated, you could try using validation lists. This will restrict the field to the values in the list.
There might be other ways, but try these first. If they don't work, please provide more detail of the use case and I'll see what we can do.
Ben Lyons
Product Consultant
UK
Ben Lyons
SS&C Blue Prism
UK based
