Save as in Power point is not working
22-01-18 03:30 PM
I have created Power point object to save the power point file with Save As key "F12", but after entering the desired location the BOT is not clicking enter/Alt+N, rather it is considering the same location of the file and not the desired path, and throwing the message as "File already Exists"
Code: Opening the power point file/Press F12 (Save As)/Enter file path/Enter/Enter
The issue is it is not considering the new file path
For example: Give a file name as D:\New folder\First.pptx"
Press Enter
Result: The file is not getting saved in the D drive path and not considering it as new location
With Regards
Archana
22-01-18 07:10 PM
Try entering the new path as keystrokes rather than using a Write stage. Some apps are not able to 'sense' that data has been entered via Write stage and you need to adopt a more 'human' data entry method.
