Scenario's where RPA fails to add in to queue
AravindBabu
Hi All,
I would like to know the scenario's where bot/RPA/digitalworker fails to add the case in to the queue.
Thanks & Regards,
Upputuri Aravind Babu
Member Technical, ADP
Rambo27
Level 8
Hi Aravind,
Can you explain what is failing the case to add into queue ?
Shikhar Mishra
RPA Lead
PvD_SE
Level 12
Hi Aravind,
The bot being unable to put cases to the Q is very rare. In fact, I've never encountered it. As Shikhar correctly indicates, you have to provide more details. Are you actually experiencing this problem or is it a situation you are considering to handle in case it occurs?
Happy coding!
Paul
Sweden
Happy coding!
Paul, Sweden
