Schedule doesn't work
SantiagoUrruti
Hello everyone, I facing an issue with the execution of procees with the scheduler, whne the process uses chrome.
I have the v6.10.2 that the table of browser compability tells that it needs to have 91.x to 109.x and I have the Versión 110.0.5481.178 (Build oficial) (64 bits).
Is this generating this issue?
Thank you all
Santiago Urruti
Mukeshh_k
Hi Santiago Urruti -Edge is more reliable in terms of doing stuffs although they both uses the same chromium package - but with the versions Edge has proved to be more efficient and reliable - mind asking me if you have edge installed and you have tried similar set of actions over edge. Also, you said it doesn't work only with scheduler - was this working good when in debug ? An error screenshot and answers to above queries might help rectifying if there's any issues with browser based things.
Mukesh Kumar
Mukesh Kumar
