Hello
We got som problems with Scheduler. For some reason it random get stuck after login, and says "Resource UDCBLUERUN7:8001 is offline - retried 3 times"
We created a simple process to check resolution from a object utility to test the problem.
Below the logs from Recent Activity from control room.
I have made some comments to the logs below.
Schedule Completed Z Test - DIRXLYA (Citrix 7) 2018-05-02 15:10:00Z 2018-05-02 13:09:59Z 2018-05-02 13:11:12Z
Task Completed Login DIRXLYA 2018-05-02 13:09:59Z 2018-05-02 13:10:04Z
Session Completed abbd1ea2-8fad-4102-8601-a34179c7aa7a 2018-05-02 13:10:01Z 2018-05-02 13:10:04Z
Task Completed Bent - Check resolution 2018-05-02 13:10:04Z 2018-05-02 13:11:09Z
Session Completed 53b7b66c-43c7-4939-b167-91e3a560fe4e 2018-05-02 13:11:05Z 2018-05-02 13:11:09Z
Task Completed Logout 2018-05-02 13:11:09Z 2018-05-02 13:11:12Z
Session Completed 1748a191-0f43-408b-bbe4-167188bce5d6 2018-05-02 13:11:10Z 2018-05-02 13:11:12Z
Schedule Terminated Z Test - DIRXLYA (Citrix 7) 2018-05-02 15:15:00Z 2018-05-02 13:14:59Z 2018-05-02 13:21:04Z
Task Completed Login DIRXLYA 2018-05-02 13:14:59Z 2018-05-02 13:15:03Z
Session Completed 96a2d462-2146-459e-9890-11ea5bed3c18 2018-05-02 13:15:00Z 2018-05-02 13:15:03Z
Task Terminated Bent - Check resolution 2018-05-02 13:15:03Z 2018-05-02 13:18:03Z Task: Bent - Check resolution threw an exception: Resource UDCBLUERUN7:8001 is offline - retried 3 times
Task Terminated Logout 2018-05-02 13:18:03Z 2018-05-02 13:21:04Z Task: Logout threw an exception: Resource UDCBLUERUN7:8001 is offline - retried 3 times
Schedule Terminated Z Test - DIRXLYA (Citrix 7) 2018-05-02 15:25:00Z 2018-05-02 13:24:59Z 2018-05-02 13:31:04Z
Task Completed Login DIRXLYA 2018-05-02 13:24:59Z 2018-05-02 13:25:04Z
Session Completed f236b260-0e8d-4439-bf13-9529be7ed871 2018-05-02 13:25:00Z 2018-05-02 13:25:04Z
Task Terminated Bent - Check resolution 2018-05-02 13:25:04Z 2018-05-02 13:28:04Z Task: Bent - Check resolution threw an exception: Resource UDCBLUERUN7:8001 is offline - retried 3 times
Task Terminated Logout 2018-05-02 13:28:04Z 2018-05-02 13:31:04Z Task: Logout threw an exception: Resource UDCBLUERUN7:8001 is offline - retried 3 times
Schedule Terminated Z Test - DIRXLYA (Citrix 7) 2018-05-02 15:35:00Z 2018-05-02 13:34:59Z 2018-05-02 13:41:04Z
Task Completed Login DIRXLYA 2018-05-02 13:34:59Z 2018-05-02 13:35:04Z
Session Completed 47410358-44a3-4a49-b0bf-604eec5e23c2 2018-05-02 13:35:01Z 2018-05-02 13:35:04Z
Task Terminated Bent - Check resolution 2018-05-02 13:35:04Z 2018-05-02 13:38:04Z Task: Bent - Check resolution threw an exception: Resource UDCBLUERUN7:8001 is offline - retried 3 times
Task Terminated Logout 2018-05-02 13:38:04Z 2018-05-02 13:41:04Z Task: Logout threw an exception: Resource UDCBLUERUN7:8001 is offline - retried 3 times
Comment: We did manuelle run logout (by drag and drop logout process to the resource UDCBLUERUN7:8001 in the control room and waited for det next schedule. Se below
Schedule Completed Z Test - DIRXLYA (Citrix 7) 2018-05-02 15:45:00Z 2018-05-02 13:45:00Z 2018-05-02 13:46:10Z
Task Completed Login DIRXLYA 2018-05-02 13:45:00Z 2018-05-02 13:45:03Z
Session Completed a0cf5ed3-6d23-4d57-846b-4137163106f3 2018-05-02 13:45:00Z 2018-05-02 13:45:03Z
Task Completed Bent - Check resolution 2018-05-02 13:45:03Z 2018-05-02 13:46:06Z
Session Completed 703fad23-8dd6-4544-9349-33fbc89aa5db 2018-05-02 13:46:04Z 2018-05-02 13:46:06Z
Task Completed Logout 2018-05-02 13:46:06Z 2018-05-02 13:46:10Z
Session Completed c1aa4568-edde-4746-bbb1-a4632e3ff669 2018-05-02 13:46:07Z 2018-05-02 13:46:10Z
Comment: The first run did work fine. But the 2 schedule failed again. But for some reason the logout did not fail. (se below)
Schedule Completed Z Test - DIRXLYA (Citrix 7) 2018-05-02 15:50:00Z 2018-05-02 13:50:00Z 2018-05-02 13:57:09Z
Task Completed Login DIRXLYA 2018-05-02 13:50:00Z 2018-05-02 13:50:04Z
Session Completed ce0a34fd-0831-4674-a58e-f472f2e16a03 2018-05-02 13:50:01Z 2018-05-02 13:50:04Z
Task Terminated Bent - Check resolution 2018-05-02 13:50:04Z 2018-05-02 13:53:04Z Task: Bent - Check resolution threw an exception: Resource UDCBLUERUN7:8001 is offline - retried 3 times
Task Completed Logout 2018-05-02 13:53:04Z 2018-05-02 13:57:09Z
Session Completed 2be860d5-6972-43ea-ab84-05adb08cd0c1 2018-05-02 13:57:05Z 2018-05-02 13:57:09Z
Schedule Completed Z Test - DIRXLYA (Citrix 7) 2018-05-02 16:00:00Z 2018-05-02 14:00:00Z 2018-05-02 14:01:13Z
Task Completed Login DIRXLYA 2018-05-02 14:00:00Z 2018-05-02 14:00:04Z
Session Completed 20399468-456b-487c-8207-8965940fb63c 2018-05-02 14:00:01Z 2018-05-02 14:00:04Z
Task Completed Bent - Check resolution 2018-05-02 14:00:04Z 2018-05-02 14:01:09Z
Session Completed 822b824b-66ef-4be4-897e-19ec803584a4 2018-05-02 14:01:05Z 2018-05-02 14:01:09Z
Task Completed Logout 2018-05-02 14:01:09Z 2018-05-02 14:01:13Z
Session Completed ddfd9075-9ab3-4f10-a91b-79c3844aefbb 2018-05-02 14:01:10Z 2018-05-02 14:01:13Z
Schedule Completed Z Test - DIRXLYA (Citrix 7) 2018-05-02 16:05:00Z 2018-05-02 14:05:00Z 2018-05-02 14:09:07Z
Task Completed Login DIRXLYA 2018-05-02 14:05:00Z 2018-05-02 14:05:03Z
Session Completed aeb58cff-f34b-4b59-8dcb-51d2a9752932 2018-05-02 14:05:00Z 2018-05-02 14:05:03Z
Task Terminated Bent - Check resolution 2018-05-02 14:05:03Z 2018-05-02 14:08:04Z Task: Bent - Check resolution threw an exception: Resource UDCBLUERUN7:8001 is offline - retried 3 times
Task Completed Logout 2018-05-02 14:08:04Z 2018-05-02 14:09:07Z
Session Completed 46a152fb-3888-4b8f-8e37-90290e5c70e3 2018-05-02 14:09:04Z 2018-05-02 14:09:07Z
Schedule Completed Z Test - DIRXLYA (Citrix 7) 2018-05-02 16:10:00Z 2018-05-02 14:09:59Z 2018-05-02 14:14:06Z
Task Completed Login DIRXLYA 2018-05-02 14:09:59Z 2018-05-02 14:10:04Z
Session Completed efd20bd2-1296-41bd-b3c5-1fee4f60f104 2018-05-02 14:10:00Z 2018-05-02 14:10:04Z
Task Terminated Bent - Check resolution 2018-05-02 14:10:04Z 2018-05-02 14:13:04Z Task: Bent - Check resolution threw an exception: Resource UDCBLUERUN7:8001 is offline - retried 3 times
Task Completed Logout 2018-05-02 14:13:04Z 2018-05-02 14:14:06Z
Session Completed 792886f4-28ee-46f7-b1d6-fbf8e108c3ce 2018-05-02 14:14:04Z 2018-05-02 14:14:06Z
Schedule Completed Z Test - DIRXLYA (Citrix 7) 2018-05-02 16:15:00Z 2018-05-02 14:14:59Z 2018-05-02 14:19:08Z
Task Completed Login DIRXLYA 2018-05-02 14:14:59Z 2018-05-02 14:15:04Z
Session Completed 842e1616-658e-4fb6-baf5-84b22104734a 2018-05-02 14:15:01Z 2018-05-02 14:15:04Z
Task Terminated Bent - Check resolution 2018-05-02 14:15:04Z 2018-05-02 14:18:04Z Task: Bent - Check resolution threw an exception: Resource UDCBLUERUN7:8001 is offline - retried 3 times
Task Completed Logout 2018-05-02 14:18:04Z 2018-05-02 14:19:08Z
Session Completed 721e4968-33a1-46a6-b283-c9e69d791c5b 2018-05-02 14:19:05Z 2018-05-02 14:19:08Z
Schedule Completed Z Test - DIRXLYA (Citrix 7) 2018-05-02 16:20:00Z 2018-05-02 14:19:59Z 2018-05-02 14:27:07Z
Task Completed Login DIRXLYA 2018-05-02 14:19:59Z 2018-05-02 14:20:03Z
Session Completed 51571d7c-6c0b-4969-9ffe-d4e86cd6244f 2018-05-02 14:20:00Z 2018-05-02 14:20:03Z
Task Terminated Bent - Check resolution 2018-05-02 14:20:03Z 2018-05-02 14:23:03Z Task: Bent - Check resolution threw an exception: Resource UDCBLUERUN7:8001 is offline - retried 3 times
Task Completed Logout 2018-05-02 14:23:03Z 2018-05-02 14:27:07Z
Session Completed c57c7f86-6089-402d-8f10-a5ea353850d6 2018-05-02 14:27:04Z 2018-05-02 14:27:07Z
Comment: For som reason the logout task also failed after some tryes. Se below
Schedule Terminated Z Test - DIRXLYA (Citrix 7) 2018-05-02 16:30:00Z 2018-05-02 14:29:59Z 2018-05-02 14:38:03Z
Task Completed Login DIRXLYA 2018-05-02 14:29:59Z 2018-05-02 14:30:03Z
Session Completed 99e761e6-d1d0-45b6-b668-9210f7840c5c 2018-05-02 14:30:00Z 2018-05-02 14:30:03Z
Task Terminated Bent - Check resolution 2018-05-02 14:30:03Z 2018-05-02 14:33:03Z Task: Bent - Check resolution threw an exception: Resource UDCBLUERUN7:8001 is offline - retried 3 times
Task Terminated Logout 2018-05-02 14:33:03Z 2018-05-02 14:38:03Z Task: Logout threw an exception: Resource UDCBLUERUN7:8001 is offline - retried 3 times
Comment: Now the login also fails, because of the logout problem. Se blow
Schedule Terminated Z Test - DIRXLYA (Citrix 7)2018-05-02 16:40:00Z2018-05-02 14:39:59Z2018-05-02 14:43:00Z
Task Terminated Login DIRXLYA2018-05-02 14:39:59Z2018-05-02 14:43:00Z Task: Login DIRXLYA threw an exception: Resource UDCBLUERUN7 is offline - retried 3 times
Schedule Terminated Z Test - DIRXLYA (Citrix 7)2018-05-02 16:45:00Z2018-05-02 14:44:59Z2018-05-02 14:48:00Z
Task Terminated Login DIRXLYA2018-05-02 14:44:59Z2018-05-02 14:48:00Z Task: Login DIRXLYA threw an exception: Resource UDCBLUERUN7 is offline - retried 3 times
