Scheduler not executing processes
NicholasD_Agost
I have setup a schedule in the Scheduler to execute a process at a certain time of the day. However, it does not execute the process even though there are no processes running on the runtime resource. I have tried to click "run now" and found that it works so i know that i have set up the schedule correctly.
Any suggestions?
HarpreetKaur
Level 7
Hello Nicholas,
Do you have an App Server set up on your machine?
Please note that the Scheduler functionality is independent of the database. It needs an App server to function. You can set it all up on the same machine, no need to provision extra RRs.
The connection setup ideally follows the below path:
IC's and RR's connect to App Server >> App Server connected to BP DB.
Hope this helps.
Harpreet
