Hi Sushma,
The current action '
Extract Regex Values' of '
Utility - Strings' VBO has a limitation of extracting any repeated occurrences of a given regular expression match to it since it can only extract the first available regular expression match. Hence, I modified this VBO for one of my use cases in order to get multiple occurrences match. I tweaked the code a bit more as you also need the positions along with the regular expression matches.
You can make a copy of the existing '
Utility - Strings' VBO or make a new custom business object from the scratch. In the
'Initialise' page of your VBO, under the '
Code Options' tab of your Page Description stage be sure to check if you have the following '
Namespace Imports' and '
External References' first with your '
Language' selected as '
Visual Basic'.
External References:
System.Data.dll
System.Xml.dll
System.Drawing.dll
Namespace Imports:
System
System.Drawing
System.Data
System.IO
System.XML
System.Diagnostics
Microsoft.VisualBasic
System.Data
system.text.regularexpressions
System.Text
System.Collections.Generic
Microsoft.VisualBasic.FileIO
Now, create a new action called '
Extract Regex Values For Multiple Occurrences' with two input parameters named '
Regex Pattern' of type '
Text' and '
Target String' of type '
Text' along with an output parameter called '
Result' of type '
Collection' and map the data items accordingly.
Add a code stage now, called '
Extract Multiple Values' with the below arguments and code:
Code:
Dim output As DataTable
Dim regexObj As Regex
Dim currentPosition As Integer
output = New DataTable()
output.Columns.Add("Match Result",GetType(String))
output.Columns.Add("Position",GetType(Integer))
regexObj = New Regex(Regex_Pattern)
currentPosition = 0
For Each matchElement As Match In regexObj.Matches(Target_String)
currentPosition = Target_String.IndexOf(matchElement.Value, currentPosition+1)
output.Rows.Add(matchElement.Value,currentPosition)
Next
Result = output
You can now test the same logic either from process studio once you publish this action or from the action page itself. So here I have provided the inputs as follows:
And upon running the workflow, my output is as follows:
NOTE: The position value here in this collection indicates the position considering that the index starts from 0 and end at 'N-1'. Which means if the text to be searched is at first position for example, then the position would be returned as '0'------------------------------
Website:
