28-11-18 07:37 PM
I am using BP version 6.4 and have been experiencing an issue when I attempt to modify
the surface automation after selecting the option from the Application Modeller window:
Regions --> View overlaid on existing screenshot
When I go back in and attempt to modify/add previously spied elements using surface automation
in the Blue Prism Region Editor (selecting Regions --> View overlaid on existing screenshot),
and return back to the Application Modeller window, I receive the following error message:
"Error occurred while retrieving screenshot / regions"
At this point, most, if not all, of my previously spied elements disappear from the Application Explorer
tree.
Here is the error message:
System.NullReferenceException: Object reference not set to an instance of an object.
at AutomateUI.clsRegionConvert.SetRelativeParentRegions(List`1& spyRegions, clsApplicationRegion appRegion, ICollection`1 appRegions)
at AutomateUI.clsRegionConvert.ToSpyRegions(ISpyRegionContainer cont, ICollection`1 appRegs)
at AutomateUI.frmRegionEditor.GetRegions(IWin32Window owner, Bitmap img, ICollection`1 currRegions, EventHandler apply)
at AutomateUI.frmIntegrationAssistant.CaptureRegions(clsRegionContainer cont)
at AutomateUI.frmIntegrationAssistant.HandleOpenScreenshotClick(Object sender, EventArgs e)
19-08-20 10:03 AM
Hi John,
Sorry for the very late reply, and I'm sure you've found the answer to your question now.
However, in case you haven't or if someone else is looking for an answer to this: in my experience this error will occur when trying to re-spy element at parent levels. To keep this from happening again, ensure that all elements spied using the region mode are child level elements in the application modeller.
Hanne
Blue Prism Developer
Hanne Bakken
Hanne
Hanne Bakken
19-08-20 10:03 AM
Hi John,
Hanne
Hanne Bakken
Hanne
Hanne Bakken
