Training Material not showing
FrankieTEWV
Hello All,
I was wondering if someone could help ....
My issue is that i need to do the consolidation exercise in the training to be able to do my associate developer exam.
It says that i need to go to C:\Program Files\Blue Prism Limited\Blue Prism Automate\VBO to install the BPA Object - MS Excel.xml file however that file path does not exist as there is no Blue Prism Limited in Program Files so unable to import the MS EXCEL VBO.
I have the file Orders.csv in the file path C:\BluePrism\Training\Applications\Windows just not the business object is there anyway that the  BO can be sent to me so i can import it please.
Frankie
Frances Legg
Hi @Frankie Legg
You can also download VBO from the official Digital Exchange portal from here.
And then import in your blue prism.
Good luck with your exam, let us know if any help is needed.​
Thanks & Regards,
Tejaskumar Darji
Sr. Consultant-Technical Lead
