Unable to connect to Default Connection
DavydLovejoy
I have been working with my client through a VM for the past 2-3 months with blue prism working fine.
This week I encountered a problem while attempting to connect to the default connection I have been using throughout this project. I have requested that the application server be restarted as this is the endpoint that is being referenced in the below message.
However I would like to know if anyone has encountered this? I do not know if this is the correct way to proceed.
Hi Davyd,
Please see the below support article, this should help resolve this issue;
http://portal.blueprism.com/customer-support/support-center#/path/1301358442
Chris
