VPN problems in Blue Prism
jose_manuelvive
Hi guys!
I have to robotize some API calls from Blue Prism.
To access these calls I need to be connected to a VPN, this connection is done through Proxifier and Xshell.
The problem is that from Blue Prism I can't connect to the VPN, the API calls always answer "Timed Out". But from Postman, for example, I do connect to the VPN and the calls work.
Do you know what could be happening?
Thank you very much!
VedSengupta
Hello Jose,
What type of API are you calling?
And are the certificates for the API correctly configured?
Best regards,
Ved Sengupta
------------------------------ Best Regards, Ved Sengupta RPA Developer Deloitte India (Offices of the US) Bangalore | INDIA *If you find this post helpful mark it as best answer* ------------------------------
jose_manuelvive
Hi Ved,
It is a simple get.
The API is well configured, there was a time when it worked, but it no longer exits through the VPN.
I don't know if it's a proxy issue.
EVIPUTI
Have you tried extending the time in System>Objects>Web API Services> Connection Settings  ?
