Warnings issue for VM on daily basis run
PrasathVarma
after entering MIRO t-code sap application is going into not responding state hence blueprism not responding on that scenario  also VM going for Warnings state in control room and not going for retry logic even after the time out is 15sec need solution to resolve this issue
Prasath Varma
esaugos
Hi Prasath,
If warning state is seen in the control room, then the process will not attempt for a retry. Also, you can below by making it as 0 to disable warning from the system settings.
But, Please note, this settings will get effected for all the processes running in your Environment.
Another way could be, Check the session logs from control room and observe the action stage after which your process reached a warning stage.
You can change the warning Threshold of that action stage to 0 as shown below.
If none of them works, then check for infinite loops if any in your code.
System Settings (By Default = 5)
Individual Process or Object Action Settings : (By Default = 5 minutes)
Saurabh Goswami
Ericsson India Global Pvt. Ltd.
Saurabh Goswami
