Way to schedule a process bi- monthly or bi-weekly
01-04-19 05:53 PM
Help required to schedule a process bi- monthly or bi-weekly.
Thanks.
02-04-19 08:05 PM
Hi, Mayur,
did you check the options in Scheduler? If you choose weekly or monthly then there is an option Every xx weeks where you enter 2 and it is bi-weekly or bi-monthly depending on what interval you chose before.
regards,
Zdenek
30-05-19 01:00 PM
You can also create your custom calendar from System->System->Calendar.
Ravinder saini
Consultant
Ernst & Young India
Ravinder saini
Consultant
Ernst & Young India
