Weird Characters added to first header when using Get CSV Text as Collection
SaraBardaji_Ser
Hi, I would really appreciate any help with this problem.
I am using the Get CSV Text as Collection action form the Utility - File Management VBO and when it reads the first header it adds some strange characters. For example: id the first ehader is ID, then the Collection has ID as its header.
Any way to avoid this from happening? Thank you in advance.
PabloSarabia
Level 11
Hi @SaraBardaji_Ser
Probably, the problem is with the encoding of the file.​ (UTF-8, ASCII....)
Can you check wich encoding are you using?
See you in the community, bye 🙂
PvD_SE
Level 12
With the risk of stating the obvious:
In addition to Pablo's likely correct answer I can add that Windows WordPad may not be the optimal tool of choice to check your file for funny characters. I'd recommend to use NotePad++ instead.
Happy coding!
Paul, Sweden
