Hi
@JayrajKuchekar1The Refresh button re-load the information in the Blue Prism Application Window. For example, if you are in the Control Room >> Queue Management and your process are inserting Items, you must to Refresh to check the new information.
This is the Refresh button:
Then, the Reset button restore the Application Diagram to the original stage clearing the current information. This button is part of Controlling Play section.
This is the Reset button.
Hope this helps you
🙂See you in the community, bye
Pablo Sarabia
Architect
Altamira Assets Management
Madrid
634726270
