What should be the VW lock/unlock/sleep setup if I'm using Surface Automation
What should be the VW lock/unlock/sleep setup if I'm using Surface Automation in production
Generally, the prod VMs gets locked after some time but the BP process keeps running in background so trying to understand the behavior.
For Surface Automation and UIA mode for both what should be the configuration?
Thanks & Regards,
Tejaskumar Darji
Sr. Consultant-Technical Lead
Neel1
Hello Tejas - We have removed the lock setting altogether in Prod VM to have uninterrupted run  .
Neeraj Kumar
Technical Architect
