Work Queue - Environment Locks
CoryLavigne
Has anyone had any luck finding documentation on how to effective utilize the environment locks? Or have any tips/tricks?
MetVonghiran
Hello, Clavign   For documentation, the environment is briefly introduced in ""Solution Design"" document. I think you would better of download the process template and look at how the environment lock works (I found it much more clearer to understand).   Regards, Met Vonghiran
david.l.morris
Level 15
There is also some documentation in the F1 Help in Blue Prism. Search for 'Environment Locking'.
