Work Queues - Total Work Case Time
AnastasiosKrap1
Hi Team,
currently we observed something strange with the 'Total Case Duration' in the Work Queues sections. Specifically, the case duration looked like this :
26397.pngCan you please let me know how can we translate this ? The representation the duration is confusing. I understand that the duration pattern is the following : hh:mm:ss.sss
But how do you translate the 114.07:47:46.000 ?
Thank you
Tasos
I think the 114 is days
John Carter
Professional Services
EVIPUTI
Hi ,
Its DTIME format -->
DTIME DD HH:MM:SS.ss 00 04:31:17.01
[Vipul] [Tiwari] [Senior Process Simplification and Optimization Developer]
[Fidelity]
NileshJadhavBP
Level 10
Hi Anastasios,
This is just suggestion from my end to resolve this.
When you are extract report data from work queue and Blue prism fetching and storing same data in excel.Please do below mention point
1.use replace function to remove last character '.000' ( as per above screenshot this is pattern)
2.Use len function to get count of entire duration length.
3.use instr to find '.'
4.use left function to get text to remove.
5.now use replace to remove first left number.
use calculation stage to perform the above activity.
after using above points you will get clean time.
Nilesh
Nilesh Jadhav
Senior RPA Specialist
ADP
Pune
Nilesh Jadhav.
Consultant
ADP,India
