multiple workstations running same robots script - will this lock processing to 1 table?
Hello, All. Can Blue Prism robots run on multiple workstations at the same time? We are trying to confirm if both robot scripts will be able to access a single source table for data (since each script will be running for a different region - meaning they should not be extracting the same data - just the same target table)
Everything in Blue Prism training is about creating scalable and robust solutions that can run concurrently on multiple resources/robots.  If you are unsure of how that can be done I strongly recommend you return to the training courses and maybe have this discussion with whoever has been mentoring/training your team. In a nutshell, the use of work queues for every solution (it should be mandatory) and the mandatory use of environment locks whilst loading work ensures multiple robots can work the same process accross multiple sessions.   The use of Process Templates and Process Examples ensure you implement best practices.
