07-11-23 12:30 PM
07-11-23 04:58 PM
Hi Mehak,
An "Object variable or With block variable not set" error when using the Outlook VBO is usually caused when there are no Inputs Parameter values assigned to the action. To resolve this issue we recommend to always assign an input value to at least one of the Input Parameters.
Alternately, have you tried using the latest version of the Outlook VBO on the DX to see if it helps?
12-11-23 01:31 AM
Hi Hari,
I already had a similar problem.
Do any of the error cases have the attachment have the character "!"? I had a problem when sending emails that had some special characters, at the time I normalized them before including them in the object input.
Leonardo Soares
RPA Developer Tech Leader
Bridge Consulting
América/Brazil
