Hi Nico.
I would suggest you to once create a separate Detach action for your login object and use that before using the Attach operation on the other object. Also, ensure that while attaching you are providing the right windows title parameter or the process name whichever is suitable as per your requirement.
We have seen in past that while working on multiple websites on same browser, sometimes issue occurs if we do not detach one of the object before attaching to another, however it happens at times though still would be a point to check once.
Intelligent Process Automation Consultant
Blue Prism 7x Certified Professional
Website:
