doran.george
Status: Needs More Info
Ability to call Chorus Rest API to work select by process model.  If a UserID has access to several deployed solutions, there is no way to limit work accept to 'change' work select privileges to queues.  Having options on Rest API call to single out which process model to get work would eliminate the need for one user to have multiple signons per deployed solution.
2 Comments
Status changed to: Reviewed
namarnani
Can you please share some examples or screenshots of the ask?
ustevens
