doran.george
Status: Needs More Info
Ability to call Chorus Rest API to work select by process model.  If a UserID has access to several deployed solutions, there is no way to limit work accept to 'change' work select privileges to queues.  Having options on Rest API call to single out which process model to get work would eliminate the need for one user to have multiple signons per deployed solution.
3 Comments
Status changed to: Reviewed
namarnani
Can you please share some examples or screenshots of the ask?
ustevens
doran.george
Health Care Group has more than one process model solution:  Claims, Mailroom, Customer Service, Inquiry, EOB processing, etc.   The ability to specify in your profile which process models to work select, this can be control by a user's security level. (not all uses would have the ability to set which process models to work select from).  You still maintain your BA/WT work select rules; the process model sits on top.   From a Rest API, the process model name or names would be part of the body for GET work select.
