We are forced to use the migration strategy when upgrading Blue Prism because we need the following features.
- The original environment can remain operational during the upgrade (Fallback!)
- Advantage of a clean start (Performance!)
- NO Downtime is required to perform the upgrade (Stability!)
Follow link for more details:
High-level upgrade strategies (blueprism.com)
But there is some potential for optimization with the migration strategy.
- Please add a feature to Blue Prism Automate for exporting and importing credentials.
- The passwords should be encrypted for security reason.
- There need to be the same encryption key in the target environment.
- After the import another encryption key can be generated to re-encrypt all credentials and the old credential key could be deleted.
- Please add a feature to Blue Prism Automate for exporting and importing work queue items.
- When encryption is used the transport of affected information should be encrypted at export.
- The encryption key for the work queue need to be transferrable / reusable in the target system.
- After the transfer of the data the old encryption scheme should be replaceable by a new one.
The main benefits of these features are...
- Safe and secure transfer of credentials and work queue items on migration.
- More flexibility for switching between environments outside of migrations.
- Less effort for building and maintaining workarounds when trying to create an alternative transfer solution.
Thanks in advance
