AmiBarrett
Level 12
- Mark as Read
- Printer Friendly Page
02-08-23
04:49 PM
Status:
New
We're running into an issue where Hub is failing to handshake with our SQL instance due to a discrepancy in the expected type of encryption. We are able to successfully connect to the SQL instance from the Application Server using connection string arguments. Please allow for the same functionality when asking for information to connect to SQL where required in the installation of other components as well.
Edit: This problem is currently specific to Hub 4.7. We are installing it alongside a 7.2.0 x64 environment.
