sand4128
Status: Delivered
Hi ,
Decipher Data verify option which when enabled allows unattended automation capabilities and when disabled provides the business with the flexibility of making sure that they verify each document before decipher completes the processing.
This is a great feature however it's ONLY available at the application level and not at DFD or ML level. This can be a deal breaker if different DFD/ML have different requirements where some may want to manually verify each document where some would want the automation to run unattended irrespective of whether the OCR accuracy was high to not. Please enhance this feature such that its available at a more granular level (DFD/ML etc).
