The "Mark Exception" action automatically creates a tag if the Exception Reason is not empty. The automatically generated tag has the format: "Exception: {Exception Reason}".
The exception reason often contains case-specific data. E.g., "product 523462 could not be found.". Blue Prism then creates a tag from this exception reason, causing our BPATag table to grow indefinitely.
