Would be great to have access to create code blocks in process level, this to skip all the hassle of creating a new object find all the dlls etc just to build some logic and then call the object from a process.
if the code block was reachable from both levels you could easily build small unique blocks for a single process/purpose, and not litter the object level with several custom code blocks.
