Our printserver service occassionally fails, causing documents to be manually printed from the Communications error queue. The JVM Heap Size is at a max of 1 GB. To increase it to 2GB, we need a 64-bit JVM. However, the current printserver service only allows for a 32-bit JVM.
We would like the printserver service for 64-bit JVM so that we can have an increased JVM Heap size so that the printserver service does not fail
