Walter.Koller
Level 12
Status: New
I am not sure if such feature is available in BP v7 at least I am not aware of it.
The idea is to have a tool that supports the replacement of VBO and sub-process in depending objects. Since the underlying XML is well defined and known it should be possible to create a program, script, VBO that list all objects used by a specific VBO/process and then allows to specify with what this should be replaced.
In theory this replacement could be done directly in DB but might be safer to extract the XML and do the replacement on the file and import it again. (export/import could be done manually). This exp-/import the replacement would be visible in the change history too.
Alternatively it would be helpful to publish the XML definitions so customers could do such a tool themselves.
