blue_meanie
- Mark as Read
- Printer Friendly Page
26-01-22
10:17 AM
Status:
New
It would be great if there was a function to allow you to view what logging level each stage had, without having to click into each one separately (or work your way through the logs after testing).
Was thinking something along the lines of a colour coding of the icons, maybe a small coloured dot in the corner, with a different colour for Enabled/Log Errors Only.
Or maybe a report from the Debug menu, similar to the Validation page, which would show a list of all stages and their respective Logging levels, which allowed you to change it from that screen.
2 Comments
