Now, can you show me where the ItemKey column value is being set up in your workflow. This is definitely a custom generated column and it wont be a part of your input file (you can also cross verify that)
I think I found it in one of the workflows I had for the challenge:
Here they are creating this column value via some formula and that same column name is being used in your queue configuration that is why it is getting mapped like that and you are also able to use the same formula in your 'Is Item In Queue' action while verifying if any queue item with same key name as generated by the formula already exists or not
Website:
Hope it helps you out and if my solution resolves your query, then please mark it as the best answer
WonderBotz India Pvt. Ltd.
