Hi Vinod,
You dont even require the LINQ dll for this. This only needs the namespace import '
System.Collections.Generic' to be added separately along with the default namespace imports that get generated automatically whenever you create any new business object. You can see the below screenshot for reference:
The error you are getting might be due to the fact that you are not declaring the data type of the row variable in the for each statement. I do not need to do that sine I guess I am on Blue Prism v.6.10.4 which uses an updated .NET runtime environment.
You can try this updated code and check if it works:
Dim listOfFields = New List(Of String)()
For Each row As System.Data.DataRow In Field_Names.Rows
listOfFields.Add(row("Fields").ToString())
Next
Output_Collection = Input_Collection.DefaultView.ToTable(True,listOfFields.ToArray())
Here, I have just added the highlighted section of the code to declare the variable row as a DataRow() class type object.
WonderBotz India Pvt. Ltd.
Website:
https://devneet.github.io/Email:
devneetmohanty07@gmail.com----------------------------------
Original Message:
Sent: 06-23-2022 11:00
Subject: Get Unique Values from more than one column in a collection
Hi @Devneet Mohanty
I tried your code but got an error saying "row is not declared".
add the Namespace Imports: 'System.Collections.Generic' and added System.Linq.dll .with the language is selected as 'Visual Basic'.
Am I missing any specific dll for the above code?
vinod chinthakindi
Original Message:
Sent: 06-22-2022 09:42
Hi Vinod,
You can extend the 'Collection Manipulation' business object and add the Namespace Imports: 'System.Collections.Generic' on the Page Description stage of your Initialize action for the LINQ queries to work properly. Also, ensure that the language is selected as 'Visual Basic'.
Once you have the updated code options as shown above, create a new action named 'Get Unique Values' and pass two input arguments, 'Input Collection' (Collection) and 'Field Names' (Collection) having a single column called 'Fields' of text data type. Based on the field name in each row of the Field Names collection unique rows will be fetched from the Input Collection. Also set an Output parameter as 'Output Collection' (Collection) for this action as shown below:
Add the code stage and use the below code with the input and out arguments as show:
Dim listOfFields = New List(Of String)()For Each row In Field_Names.Rows listOfFields.Add(row("Fields").ToString())NextOutput_Collection = Input_Collection.DefaultView.ToTable(True,listOfFields.ToArray())
The run results are as follows:
Input Arguments:
Output Result:
You can publish the action and test the same from Process Studio. Let us know if this helps you out :)
Original Message:
Sent: 06-22-2022 08:01
Hi
I have a scenario where I have to get unique values from more than one column in a collection. Right now I am achieving this using loops which is taking more execution time due to high number of records. I am looking for a using code stage to achieve similar thing or any other method with less execution time.
Example:
Input Collection
ID Name Email Mobile
1 A A@GMAIL.COM 91****
2 B B@GMAIL.COM 91****
3 C C@GMAIL.COM 91****
4 A A@GMAIL.COM 91****
5 B B@GMAIL.COM 91****
6 D D@GMAIL.COM 91****
Expected Output Collection:
Name Email
A A@GMAIL.COM
B B@GMAIL.COM
C C@GMAIL.COM
D D@GMAIL.COM
Edit:
Input collection can also has some Null Values in Email Column
vinod chinthakindi
