How to train ML model
In Decipher, how do I kick the ML model to start training?
I've around 60 documents verified but this date is not changing
In doc type, we enabled training a few days ago, but I still don't see it kicking in.
I appreciate help, guidance and working of ML model training here.
Thanks & Regards,
Technical Lead
Ben.Lyons1
Hi Tejaskumar,
Have you tried the steps on the troubleshooting page? Troubleshooting (blueprism.com)
And just in case, 10 documents is far too low to create a useable model. 50 is the minimum for a model to be created/updated, Machine learning (blueprism.com).
I would suggest between 5 and 10 documents per layout/vendor. So 100 different layouts = 500 - 1000.
Ben Lyons
SS&C Blue Prism
UK based
Ben Lyons
SS&C Blue Prism
UK based
Ok but it allows setting it to minimum of 10. And we have high variations of invoices (every vendor has multiple layouts and it will keep changing) so really can not train each and every layout, so going with the sample headers
Thanks & Regards,
Technical Lead
It is not necessary, not recommended in the best practice to enable the Capture ML model at this stage. Please refer to the best practice guide on the portal for advice on how to proceed.
Decipher IDP best practices (blueprism.com)
And I would recommend familiarising yourself with how the different style of ML in Decipher work, as this will help guide your document training.
Training models overview (blueprism.com)
Ben Lyons
SS&C Blue Prism
UK based
Ben Lyons
SS&C Blue Prism
UK based
