13-10-22 10:47 AM
I got a process in which I have a problem with 2 edge windows. When I try to attach to one of the windows and want to perform a simple action like clicking something or read/write something the "wait for process window" action which is at the start of my "attach" page can not find the process window unless I manually help the bot and click it first.
This is how my attach looks like:
It's basically the same for all the applications I use.
The wait for process action looks like this:
I use Blueprism 6.10.1 and in both edge windows I have 6.10.1 Browser extension running. In the blue prism settings I selected:  But I also tried it without it and it did not work either.
13-10-22 11:20 AM
13-10-22 12:09 PM
Unfortunately I can not do this since one the applications is started in a "special" way.
The application that I hava mentioned above is started by a different program and I just attach to the already running browser. This application is a simple website.
The other application that's running in the other edge window is started in a different way and does not have the usual Edge Window.
It will be started with the following command
C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe --app="http://xxx.yyyyy.zzz/eClient/exe/eb.exe?p=switch&MaskName=sw_start&switch=0"
The edge application window does not have any tabs or the usual edge look anymore.
All the actions I made work perfectly fine when I just test the applications individually. But as soon as I have both windows open Blue Prism is not able to find the right edge window. (unless I manually interfere and click the right window)
Do you have a different suggestion ?
13-10-22 01:33 PM
