Training Material not showing
FrankieTEWV
Hello All,
I was wondering if someone could help ....
My issue is that i need to do the consolidation exercise in the training to be able to do my associate developer exam.
It says that i need to go to C:\Program Files\Blue Prism Limited\Blue Prism Automate\VBO to install the BPA Object - MS Excel.xml file however that file path does not exist as there is no Blue Prism Limited in Program Files so unable to import the MS EXCEL VBO.
I have the file Orders.csv in the file path C:\BluePrism\Training\Applications\Windows just not the business object is there anyway that the  BO can be sent to me so i can import it please.
Frankie
Frances Legg
Best Answers
jefuytterhoeven
Hi Frances
can you please check if blue prism is intalled on the machine you are working on. Since you are doing the excercise it probably is.
If BP is not installed you will have to install the demo version for the excersise.
If BP is installed right click on the Blue prism Icon(Where you normally open it) en then click open file location. In this folder you can then go to the VBO folder where you should find the excel VBO
jef uytterhoeven
6 REPLIES 6
jefuytterhoeven
Hi Frances
jef uytterhoeven
Hello - Alternatively download MS EXCEL VBO from DX.
https://digitalexchange.blueprism.com/dx/entry/3439/solution/ms-excel-vbo
and do a file>Import into you BP UI.
Neeraj Kumar
Technical Architect
Hey Francess,
Did you download the Learning Edition when you were going through Foundations Training?
Have you checked "Program Files" and not "Program Files (x86)"?
 Just to clarify, it should be in "C:\Program Files\Blue Prism Limited", not "C:\Blue Prism" which is where Orders.csv is located.
Best of luck.
Michael Annis
Thank you so much!!  I have managed to locate that now.  i really do appreciate your help 🙂
Frankie Legg
Thank you so much for getting back to me! i have managed to locate it now 🙂
Frankie Legg
Thank you so much for getting back to me i was looking under 2Program Files" as opposed to  "Program Files (x86)" and i have now managed to locate the BO - really appreciate you taking the time to respond to me
Frankie Legg
