After 6.5.1 Upgrade Resource State is changing slowly
janikopra
​We have upgraded from 6.3 to 6.5.1. After upgrade Control Room - Resource - State is changing slowly. It takes about 1 minutes to change the state. For example if we drag and drop the "Login" process to server resource with the port (server:8182), the status of server without the port is changing to "idle" state only after 60 seconds or so.
We have checked that there is enough CPU, memory configured to server. We have upgraded the login agent correctly by uninstalling the previous version before installing 6.5.1 login agent. We have also imported the new vbo bprelease file to blue prism regarding agent.
Have someone had some kind of problems. It sounds to me that this is version problem. Is this fixed in Blue Prism 6.6? Or is there work around to this by configuring some setting etc? I didn't found any setting that is related to this.
Jani Kopra
Solution Architect
Aditro Shared Services Oy
Europe/Sarajevo
0 REPLIES 0
