I am trying to insert items into a work queue through SQL. I am using Blue Prism v7.0.1.
My questions are:
1. Is inserting a row in the BPAWorkQueueItem table enough?
2. How is the item id generated? I was trying to insert a row using SQL Server management studio and it kept giving me error on the "id" column : (Guid should contain 32 digits with 4 dashes) even when I used the correct format for the id. Is there a way to generate this id programmatically?
3. What is the queueident column for?
Any help would be greatly appreciated. I have been pulling my hair out trying to figure this out for days.
Mohammad Areeb
