Can't uniquely identify web element
Dylan
Hi there,
I'm trying to spy the output of a currency conversion on https://www.exchange-rates.org, and I can spy the output of a conversion of one currency (any I pick), but as soon as I change the currency and re-run the highlight element, it can't identify it.
I'm not sure what to do, can someone please help?
I've spied a few elements, and none of them work for more than 1 currency.
Flow:
  1. Enter input
  2. Select from currency
  3. Select to currency
  4. Hit convert
  5. Get output result (currency1)
Convert flow2:
  1. Re-enter input
  4. Hit convert
  5. Get output result (currency2)
Won't be able to find the output result of currency2.
What should I do?
Thank you!
Dylan Tanner
Dylan
I've fixed it... not sure how, but it's fixed. I just respied the element, but I did that multiple times, so I'm not sure.
Dylan Tanner
HI Dylan,
Try using just Web ID attribute to match it (usually this is first thing that I try on web pages). Page Address may be causing Your errors as it will change depending on conversion currencies.
Best regards
Michal
Michal Szumski
RPA developer
Rockwell Automation
Europe/Warsaw
This and match index solved my problem!
Thank you!!
Dylan
