Hi Ben,
That's maybe a little strange (or a coincidence), but it can take a little while for a capture model to be created.
If you have access, you can check the capture model table in the database. The status column is either 1 or 2, 1 = unlocked, 2 = locked for training.
If it happens again, it's worth checking and if the status is 1, it would be worth raising a support ticket.
Ben
Ben Lyons
SS&C Blue Prism
UK based
