05-01-23 06:24 PM
06-01-23 09:06 AM
07-01-23 12:18 PM
Hi Mark,
Can you plz let me know what is the source dir (local or SharePoint or network path) is? We can deny this from a few configs
Hi Michael, I believe that event enabled will disable the execution of macros for activated workbooks
09-01-23 06:49 AM
09-01-23 06:56 AM
09-01-23 11:33 AM
11-01-23 03:55 PM
12-01-23 08:39 PM
27-02-23 09:33 AM
Hi @prasanth-continuouslearning,
Thank you very much for such a detailed response, and my apologies for my delayed feedback.
Unfortunately, our IT team does not allow the changes that you have shared above. As a workaround, we have instead created the automation in such a way that the file is first saved locally before being copied to the SharePoint directory.
Again, thank you so much for the help!
Mark
