Code stage in object studio
vipima
We have a complex excel sheet to read, which looks for some mandatory column headers, is there anyway we could add logs and easily pinpoint where it is failing?
Inside code stage in objects, is there a way we can debug the code line by line in blueprism or see values printed by Console.WriteLine statements?
Vipin
Vipin Madathum Padikkal
MaheshKushare
Hi Vipin,
Blue Prism not support debug in code stages. but there is a way to debug with one trick 🙂
you have to place some "MsgBox" in code stage; and populate the any string so you can ​check line by line and where actually code fails.
make sure that MsgBox is only use for debug, after that delete it or comment it using single quote (ex. ' MsgBox("Hi") ).
Mahesh Kushare
Sr. Consultant
Capgemini Solutions Canada Inc
Toronto
2269886490
MaheshKushare
Hi Vipin,
Mahesh Kushare
Sr. Consultant
Toronto
2269886490
That works for me. 🙂
